Systick and stop mode
次の代わりに検索
2,925件の閲覧回数
Catosh
according to my understanding, in stop mode the SysTick should be disabled (since it's clocked from core clock):
Nevertheless, in my design (s32K11x) looks like It's nod disabled and it's able to exit from stop mode.
Is it due to the attached debugger?
Since the debugger interrupt is not mapped to NVIC I suppose it could be active, but if the core is stopped it shouldn't.
The code is really simple and generated using the SDK3.0.0:
uint8_t buff_out[]="Test\r\n";
int main(void)
CLOCK_DRV_Init(&clockMan1_InitConfig0);
PINS_DRV_Init(NUM_OF_CONFIGURED_PINS, g_pin_mux_InitConfigArr);
UART_Init(&uart_pal1_instance, &uart_pal1_Config0);
UART_SendDataBlocking(&uart_pal1_instance, buff_out, sizeof(buff_out), 0xFFFF);
//Init systick here for 350ms operation
S32_SysTick->RVR = 0xFFFFFF;
S32_SysTick->CVR = S32_SysTick_CVR_CURRENT(0);
S32_SysTick->CVR = 0;
S32_SysTick->CSR = S32_SysTick_CSR_TICKINT(1) | S32_SysTick_CSR_ENABLE(1);
S32_SCB->SCR = S32_SCB_SCR_SLEEPDEEP(1);
SMC->PMPROT = SMC_PMPROT_AVLP(1);//VLPR and VLPS are allowed
SMC->PMCTRL = SMC_PMCTRL_RUNM(0) | SMC_PMCTRL_STOPM(0) ;//Normal mode run
SMC->STOPCTRL = SMC_STOPCTRL_STOPO(2);
STANDBY();
while(1){
UART_SendDataBlocking(&uart_pal1_instance, buff_out, 3,0xFFFF);
STANDBY();
//asm("nop");
void SysTick_Handler(void)
__asm("nop");//Just for breakpoints
Any hint on this?
Thanks and K.R.
Luca
2,501件の閲覧回数
dianabatrlova
Hi Luca,
Yes, it is due to the attached debugger.
Please, refer to section "39.4.5 Debug in low power modes" in the RM rev 9.
... the mode controller handles attempts to enter STOP and VLPS by entering an emulated stop state. In this emulated stop state:
• all system clocks, except the core clock, are disabled,
I hope it helps.
Diana
3 返答(返信)
2,502件の閲覧回数
dianabatrlova
Hi Luca,
I hope it helps.
Diana
2,501件の閲覧回数
Catosh
Hi Diana,
yes, you were able to solve my problem.
One related question: I monitor the bus clock on the clockout pin, and I thought that it was disabled in stop1 - but I can see that it is present when I am stopped.
Is it gated at a later stage than the sample point for clockout?
K.R.
Luca.
2,501件の閲覧回数
dianabatrlova
Hi Catosh,
I'm very sorry for the delay.
I have tested this issue and I can reproduce it, unfortunately, I have no details about this behavior yet.
I will let you know if I get more information.
Thank you for your understanding.
Diana
