S32K358 board stopped programming
725 次查看
mishra1
We're working with HVBMS800BUN(RD-K358BMU). It is a reference design BMS board with S32K358 BMU.
We are programming the board using PEMicro debugger.The board instantly stopped programming. The connection is fine.
  It shows error code ""
  For your reference, we have attached the error log. Please look into it.
671 次查看
petervlna
First please try to update the PE to the latest version. You are using something outdated.
If that does not help, then try reinstalling S32DS, there is something probably missing as it cant load the arp.
Peter
672 次查看
petervlna
Peter
