Dear All,
Can you please elaborate on the S32K322 GPIO - Pad type/Category Maximum switching frequency
GPIO - Super Slow
GPIO - Slow
GPIO - Medium
GPIO - Fast
And where can we find more details ?.
Solved! Go to Solution.
you can find these info in S32K3xxDS:S32K3xx MCU Family - Data Sheet
https://www.nxp.com/docs/en/data-sheet/S32K3xx.pdf
1.Table 24. GPIO DC electrical specifications, 3.3V Range (2.97V - 3.63V)
2.Table 25. GPIO DC electrical specifications, 5.0V (4.5V - 5.5V)
I am looking for the below kind of information.
Function: This field specifies the functionality of the pad as per the corresponding ALT mode specified by SSS field.
Module: The Module field contains the module which is governing the pad for the ALT mode.
Description: This field mentions a short description of pad functionality.
Direction: This field specifies the direction (Input, Output or Input/Output) of the pad for the concerned functionality.
Pad Type: This field mentions the pad type of the corresponding pad.
GPIO-Standard:
Switching up to 10M Hz
High drive-strength not supported.
Slew-rate control not supported.
GPIO-Standard plus:
Switching up to 25M Hz
Supports high drive-strength.
GPIO-Medium:
Switching up to 50 MHz
Supports slew-rate control.
GPIO-Fast:
Switching up to 120 MHz
The next columns specify the pin number in the supported packages for the device.
But in s32K322 IOMUX Excel sheets it is classified as below
Super slow, slow, medium and fast. Where can we find more information on this .
Hi@harish_crowdnid
super slow,slow,medium and fast here refer to GPIO-Standard,Standard plus,Medium and Fast.
ok. Thanks a bunch
