S32K148 reset Led
S32K148 reset Led
1,265件の閲覧回数
faress_mansouri
when i try to download my code in s32k148 card, i get this error :
and :
   - the reset LED is turned ON
   - the MCU is heating.
does that means that my card is damaged ? if not what can i do to fix this problem ?
タグ(1)
2 返答(返信)
1,195件の閲覧回数
Jeremy_He
I have met a few times that VDD and GND are shorted somehow.  You may check that using a multimeter. If that happens, the MCU is mostly damaged.
1,195件の閲覧回数
Alexis_A
Hello Faress,
Unfortunately, due to the reset pin is being forced to a low state and the MCU is heating is very likely it stops working.
Alexis Andalon
