S32K146 64 pin package configuring clocks
erikvk
I am starting up with the supplied examples from NXP (freertos_s32k146) to run on a custom board with a S32K146 64 pin MCU. But the MCU jumps to the defaultisr when it tries to configure the clocks with the NXP supplied function `CLOCK_SYS_UpdateConfiguration(0U, CLOCK_MANAGER_POLICY_AGREEMENT);`. Insted I enable the clocks for the PORTs directly with: `PCC-> PCCn[PCC_PORTC_INDEX] = PCC_PCCn_CGC_MASK;` (for each port that I am using). And removed the CAN set up function calls. Then I will get the LEDs to light up and blink. The unmodified example works as intended on the development board with the larger package (S32K146EVB-Q144, 144pins). Are the example projects supposed to work with the other packages for the MCU S32K146 or is it just the one version on the EVB that is supported?
Br
Erik
erikvk
Thank you for your answer. I have tested the simpler example of "Hello world" platform both on the evaluation board (144 pins) and our custom (64 pin) and I get the same issue as before. I use the default configuration for the clock, using the internal crystal oscillator see picture. But the 64pin MCU still stops when trying to configure the clocks. As I understands there should be no difference between the two packages except the amount of pins or does the two different MCU need different clock configurations? I should add that the custom board have a 16Mhz crystal
Br
Julián_AragónM
Hi @erikvk,
No additional configuration should be needed for different packages. This may be a hardware error instead, please help me check chapter 3.2 of the Hardware Design Guidelines for suggestions for the PCB layout of oscillator circuit.
Julián
Julián_AragónM
Hi @erikvk.,
The examples provided in the packages are only tested with the hardware mentioned, and modifications may be needed if the package includes modifications in pins (or memory/peripherals, etc.).
My suggestion is to test the "hello_world" example from the S32K1xx SDK for the S32K146, since this is a simple application created to act as a template project for S32 Design Studio. If this example still has issues when configuring the clocks, it may point to a hardware design issue.
In that case, you can take a look into the Hardware Design Guidelines for any proofing of the design. Chapter 3 specifically describes the clock circuitry.
Julián
