S32K144 FLASH application problem
liuweiliang
MCU model number: S32K144
Downloader: J-LINK
Description of the problem: After the PFlash cache is closed, there is no problem with single-step debugging. The online DEBUG fails to run at full speed, as shown in the following figure:
Note: When running offline, check whether it is running through the indicator in the main function. The indicator does not respond, indicating that it has not entered the main loop.
deadbef5:   Failed to execute MI command:
          -data-disassemble -s 3735928565 -e 3735928721 -- 3
          Error message from debugger back end:
          Cannot access memory at address 0xdeadbef4
Configuration information:
1. Set the clock to RUN mode before configuring PFlash (normally working in HSRUN, PFlash cannot operate under high speed).
2. Close the PFlash cache and prefetch:
MSCM->OCMDR[0u] |= MSCM_OCMDR_OCM1(0xFu);
3. Initialize PFlash; write data to PFlash.
4. Enable PFlash cache and prefetch.
5, restore the working mode to HSRUN mode (112M)
ssyyw
I also meet the problem just like you, so, are u solve it? thank u! waiting for your reply!
danielmartynek
Please refer to the OCM1 description:
The below line should be executed from RAM to avoid these undesired results.
jochengerster
HI Daniel,
are there other scenarios possible, beside code execution from flash which would keep the flash controller busy / causing a problem?
Like DMA, EEE, cSEC accessing the flash?
thanks
best regards
Jochen
