S32K144: Can't change CAN clock to SYS_CLK using Can_pal component
次の代わりに検索
1,167件の閲覧回数
sripav-7
Hello
I programmed my application's CAN communication using the can_pal component, and with SOSC clock enabled. In the PCB board, I do not wish to have an external oscillator and would like to switch CAN engine clock to SYS_CLK. However, I cannot find an option to change this and can_pal library just says that protocol clock frequency cannot be 0.
If I use the flexcan component, however, this option is present. Why is it not present in the can_pal library? Can I change it to use SYS_CLK while still using the can_pal component, or is it unavoidable to port all code to use the flexcan component?
Thank you.
タグ(2)
887件の閲覧回数
danielmartynek
Which SDK version do you use?
It can be set in SDK v1.9.0
3 返答(返信)
888件の閲覧回数
danielmartynek
887件の閲覧回数
sripav-7
Hello
I use 0.8.6. I wanted to upgrade to 1.9.0, but the SDKs are apparently not fully compatible and upgrade is not very straightforward.
887件の閲覧回数
sripav-7
I upgraded the SDK and it is there now. Thank you.
