S32K144 CAN MASTER Sample Code
yash_bhatnagar9
Hi, Can anyone provide the link to the CAN Master and CAN Slave Sample code examples. I am unable to find the links to them.
Tags (2)
ArSa
Hello Robin,
Thanks for the response. From the links you have helped with it seems easy to start with an Example code. But I am having multiple issues after updating my S32DS to 3.5.
Firstly when I Help -> check for updates will lead to following error log.
Some sites could not be found. See the error log for more detail.
No repository found at http://www.nxp.com/lgfiles/updates/Eclipse/APSW/S32DS_3.5.
HTTP Server 'Bad Gateway' : http://gnuarmeclipse.sourceforge.net/updates/content.xml
HttpComponents connection error response code 502.
and Secondly when I look for Example projects the following is the view,
It seems something is missing in whole. Please help me in fixing the issue
Robin_Shen
Please ask on the S32 Design Studio forum about this issue.
ArSa
I have the error Cpu.h is not found, neither i could find it in whole C:/NXP folder. where can i find it
Robin_Shen
Robin_Shen
Hi yash_bhatnagar9,
Please refer the can_pal_s32k144 example of S32SDK
You can download the S32 Design Studio 3.4 and then install the S32SDK S32K1XX RTM 4.0.1 in S32DS Extensions and Updates view.
Robin
