S32K144 ADC collect is not correct when voltage is below 7V
669件の閲覧回数
547416104
Hello EveryOne,
 I find the ADC collect result is not correct when battery voltage is below 7V on S32k144 100pin, the test result as below:
7.6V -> 0x288
7.5V -> 0X27B
7.4V -> 0X272
7.3V -> 0X274
7.2V -> 0x275
7.1V -> 0x277
7.0V ->  0x27A
6.9V -> 0x27C
6.8V -> 0x27E
6.7V -> 0x281
6.6V -> 0x283
6.5V -> 0x286
I use SDK to config the ADC module, whether need to do other configure for ADC module, thanks
649件の閲覧回数
Robin_Shen
Can you introduce the sampling circuit? The VADIN (ADC Input voltage) to S32K1 should be between VREFL - VREFH.
Please check if VREFH changes when the battery voltage drops, and make sure that the ADC input voltage and VREFH do not change.
Robin
2 返答(返信)
650件の閲覧回数
Robin_Shen
Robin
626件の閲覧回数
547416104
The issue is fixed, HW engineer check is VREFH voltage is not ok, update the IC, the issue is fixed.
タグ(1)
