Hello @jianqun,
Please refer to the RM rev. 14, Section 52.3.2.4 Timing Parameters.
As you can see, the SCL clock period depends on the bus latency as well, which is given by the capacitance of the bus and the size of the pull-up resistors.
The RTD does not calculate with the parameters of the bus.
You will get slightly different bit rate if you use different pull-ups.
