No CAN module listed in Components Library for S32K146
搜索替代
223 次查看
547416104
Hello EveryOne,
I do not find CAN module listed in Components Library for S32K146, whether the SDK not support CAN module? if support, how to find the conpinent.
Detail information as the follow picture.
211 次查看
Senlent
I see no problem on myside.
4 回复数
216 次查看
Senlent
Hi@547416104
please change the Applicable to project to All,then try again.
214 次查看
547416104
Hello Senlent,
I have try to do follow you suggested, the the result is the same, I have attached the demmo project, could you help to check the problem, thanks.
212 次查看
Senlent
208 次查看
547416104
Hello Senlent,
I have add the can_pal module in project, I must reopen the S32DS IDE, otherwise, I can not find the CAN module, thanks.
