Need some clarification regarding Interrupt Controller - eMios
403 次查看
kyf
Contributor V
Hello NXP team!
Regarding the screenshot bellow:
1. Is EMIOS0_0_IRQn refered to eMios 0 channel 0 ?? or this is an other interrupt ?
2. Is there any document where I can find descriptions regarding the eMios interrupts except reference manual ?
3. Is interrupt priority set only withing the "peripheral tool" ?
4. Is there any handler for handling the priorities of the interrupts and their priorities ? OR this is done by hardware ?
Kind regards,
kyf
396 次查看
PetrS
1) four channle's interrupt requests are ored into single vector in eMIOS and EMIOS0_0_IRQn belongs to channels 23,22,21,20
2) it is in S32K3xx_interrupt_map.xlsx attached to the RM, also visible in project
3-4) priority is set either in the component you shown or a IntCtrl_Ip_SetPriority function can be used, i think.
BR, Petr
36 次查看
Esakki
Hi, PetrS,
We are getting an error - "Undefined reference to emios0_3_irq" while generating code in MBDT with S32DS for generating variable frequency and variable duty cycle PWM pulse.
Kindly help me for resolving this error.
Thanks & Regards,
Esakki
388 次查看
kyf
Contributor V
Thank you @PetrS for your input.
Kind regards,
kyf
397 次查看
PetrS
BR, Petr
