Regarding Low Voltage Warning, I am always reading PMC_LVDSC2[LVWF] = 1
MCU operate with 3.3V, so as per datasheet the VLVW is always set since supply remains below VLVW range.
so, this feature will not be applicable in 3.3V range?
Hello @SamirSamy,
Yes, that is correct.
The feature can be used when the MCU operates at 5V only.
