Is IPCF not supported on statically allocated operating systems?
mikesteven
@nxp teams,
hello, I encountered difficulties with integrating IPCF.
When I set FreeRTOS only with static allocation options, IPCF compilation reported an error. Is it necessary to enable dynamic allocation?
nxf78987
Hi @mikesteven,
This issues will be fixed on the SW32K3 IPCF 4.1.0 D2312 package
Dan
nxf78987
Hello @mikesteven,
What is the compilation error?
Dan
mikesteven
Hi @nxf78987
Thank you for your reply!
If I do not turn on the dynamic memory allocation option, the compilation will prompt the following error. Because the API used when creating tasks in the current IPCF is xTaskCreate, this function must use the dynamic memory allocation option to be used. But if my project does not allow dynamic memory allocation, does that mean I cannot integrate IPCF?
nxf78987
Hello @mikesteven,
What is the IPCF package version you are using?
Dan
mikesteven
Hi @nxf78987 ,
The IPCF version I am currently using is 3.4.0.
nxf78987
Hello @mikesteven,
I raised your issue to the IPCF team. They will analyze to this and check if IPCF driver can support also for static allocation.
I'm going to inform you when I get any information from them.
Dan
mikesteven
Hi, @nxf78987 ,
Thanks!
Okay, I look forward to your reply!
nxf78987
Hi @mikesteven,
Dan
mikesteven
Thank you for your notification! I have seen the modifications in version 4.1.0, thank you to the NXP team for their efforts!
