How to write CMU driver? Is there sample code?
1,001件の閲覧回数
xiaohuang
Can CMU be configured in S32? How to write CMU driver? Is there sample code?
7 返答(返信)
980件の閲覧回数
xiaohuang
I am using the S32K118 ,Then I don't know how to configure the CMU, how to verify that the configuration is correct.
983件の閲覧回数
Senlent
Hi@xiaohuang
  Can you tell me which device are you using?
  CMU is available in only S32K11x series of devices. Other products in the S32K14x series do not have CMU.
BR!
    Jim,
969件の閲覧回数
Senlent
Hi@xiaohuang
       I have sent you a routine in private,this demo just for your refenence.
965件の閲覧回数
xiaohuang
Ok, i got it, thanks you so much .I have another question, how do i test the CMU?
962件の閲覧回数
Senlent
Hi@xiaohuang
        Try to manipulate the thresholds in HTCR and LTCR registers,then generate a Loss of Clock reset when monitoring the FIRC.
BR!
    Jim,
886件の閲覧回数
xiaohuang
Thank you for the example you provided last time. How is the CMU1 threshold calculation formula derived? No related formula found on the document
973件の閲覧回数
xiaohuang
