How can i initialize "Remember my decision" in SDK Component Management
POSEIDON
I am using workspaceS32DS 3.4 for S32K144.
i'd like to keep existing in DSK component file.
However, I checked "remember my decision" and clicked replace, previously.
so i'd like to initialize checked "Remember my decision".
how can i initialize?
POSEIDON
hi,
i can not find your mentioned option in "Window > Preferences > S32 Configuration Tools".
i checked 5 options, [Generate source folder], [Always show details before update code], [Show pin label & identifier table columns], [Automatically load last configuration on startup], [Enable Code Preview].
Did not check options are  [Create empty configuration if no Yaml is available], [Always overwrite files without asking], [Require identifier for Pins].
Daniel-Aguirre
Thanks for the feedback.
This may not be our best solution, but we may have to recommend reinstalling the software, given there is no general "default settings" or "factory restore", that we see.
If we found anything else, we will let you know.
We do apologize for this.
Please, let us know.
Daniel-Aguirre
Could be that your option is related to the following configuration:
"Window > Preferences > S32 Configuration Tools > Allow component migrations"
If it is checked, it automatically migrates to newer versions of the components.
Please, let us know if this information was helpful or not.
