Flash by CAN bus
Flash by CAN bus
988 次查看
kentseng
Hi!
Is there anyone knowing of any ready solution to flash new program into a S32K144 through CAN Bus?
Some kind of bootloader supporting CAN bus?
Or any possibility to adapt Kinetis Bootloader to work with S32K144?
Thank you!
982 次查看
PetrS
you can refer to below resources:
AN12323 - CAN bootloader:
https://www.nxp.com/docs/en/application-note/AN12323.pdf
https://www.nxp.com/docs/en/application-note-software/AN12323SW.zip
Demo of Unified bootloader stack based on UDS and CAN/LIN TP protocol:
https://www.nxp.com/downloads/en/snippets-boot-code-headers-monitors/unified_bootloader_framework.zi...
Hope this helps.
BR, Petr
