Can't send/receive SPI messages longer than 40Byte
594 次查看
TaehoLee
I'm using -> MCU : S32K144, IDE : S32DS ARM 2.2
Currently, I'm implementing 176Byte long SPI messages transmit/receive function.
with the SPI bare-metal example code
If I increase the Frame size register in TCR, up to 320bit(4 * 10Byte) it works well
But, If I try to send/receive bigger values it doesn't work.
for example from my code
 uint32_t spi_tx[44] = { 0x1, 0x2, 0x3, 0x4, 0x5, 0x6, 0x7, 0x8, 0x9, 0xA,
 0xB, 0xC, 0xD, 0xE, 0xF, 0x10, 0x11, 0x12, 0x13, 0x14,
 0x15, 0x16, 0x17, 0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E,
 0x1F, 0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28,
 0x29, 0x2A, 0x2B, 0x2C };
 uint32_t spi_rx[44] = {0,};
void LPSPI0_tx(void)
for(i=0;i<10;i++)
while((LPSPI0->SR & LPSPI_SR_TDF_MASK)>>LPSPI_SR_TDF_SHIFT==0);
LPSPI0->TDR = spi_tx[i];
LPSPI0->SR |= LPSPI_SR_TDF_MASK; /* Clear TDF flag */
void LPSPI0_rx(void)
for(j=0;j<10;j++)
while((LPSPI0->SR & LPSPI_SR_RDF_MASK)>>LPSPI_SR_RDF_SHIFT==0);
spi_rx[j] = LPSPI0->RDR;
LPSPI0->SR |= LPSPI_SR_RDF_MASK;
If I use i,j = 10 and frame size = 319(320bit) it works well
But, If I use i,j = 11 and frame size = 351(352bit) it doesn't work
Can I find an answer?
5 回复数
588 次查看
danielmartynek
Hello @TaehoLee,
First of all, the TDF / RDF flags get set / cleared automatically by the LPSPI module depending on the state of the TX / RX FIFOs.
You did not post the Transmit command that you use, can you share it?
Do you mask the RX data (RXMSK = 1) of this transfer?
Because I don't see how you could receive all the data, there is only 4-word RX FIFO.
Can you poll the RX data within the loop whare you write the TX data?
Thank you,
BR, Daniel
586 次查看
TaehoLee
Basically, I just called spi tx/rx function in the main function like below for the test purpose.
for(;;)
LPSPI0_tx();
LPSPI0_rx();
counter++;
I didn't mask RX data, Because I also had to receive SPI data
other SPI configurations are the same as the example code
Also, I tied MISO/MOSI line together in the PCB(S32K144 EVB)
My intention was that check spi tx/rx data with the same board.
I'm also stranging why rx data have been received and watched at the IDE
Can you show the example? how to send/receive 180Byte long SPI messages?
I difficult to find an answer to how to send SPI messages that are longer than 32bit
After increasing frame size register how to send/receive spi data?
582 次查看
danielmartynek
I can modify the example to send and receive 180bytes, but it will take a while.
Can you try masking the RX data, or read it before the RX FIFO overflows?
I think this is the issue here.
BR, Daniel
579 次查看
TaehoLee
Thank you for your help
After I set RXMSK TX is sending well However, I have to receive SPI rx data also.
I tried to read SPI data after sending 1st SPI word but, RDF was not set.
So, how to read a message during SPI messages transfer?
568 次查看
danielmartynek
Hi @TaehoLee,
I would recommend enabling Receive Data Interrupt (RDIE).
You can set the RXWATER to a higher number so that the interrupt is not called for each word.
Otherwise, you will need to poll the SR_RDF flag and read the data in time to avoid FIFO overflows (SR_REF).
BR, Daniel
