Any way to vary the duty cycle in the runtime? And also LED Brightness?
Shrini
I want to vary the duty cycle in the run time. So that I can observe the pwm signal. And also want to change the LED brightness using potentiometer. Is it possible to do in the s32ds using s32k144 board?
VaneB
Hi @Shrini
SDK: FTM_DRV_UpdatePwmChannel
RTD: Ftm_Pwm_Ip_UpdatePwmChannel
MCAL: Pwm_SetDutyCycle
VaneB
Hi @Shrini
Yes, it is possible to change the duty cycle of a PWM. You need to change the value of the CnV register
FTM_->CONTROLS[channel].CnV= value;
I suggest you look at the included examples on the SDK/RTD or in the S32K1xx Series Cookbook.
B.R.
VaneB
Shrini
Hello @VaneB, I am thinking to do this task using API's not in register level coding.
VaneB
Hi @Shrini
Shrini
Thank you @VaneB
