hello
I use the s32k146 chip,and the watchdog resets when it goes timeout.Now i want to add a funcion to reset the system actively,Does the chip have a active reset register?
Best regards!
Solved! Go to Solution.
Hi qiu,
Please check whether the Software reset (SW) meets your needs:
Robin
Hi qiu,
Robin
Hi @Robin_Shen ,
Thanks for sharing the information.
would you like to share the software reset sample code by using S32K116 MCU.
After the assignment as below method, use the Debug tool to observe that the value does not change, and the reset fails, would you like to share your comments. thanks.
Best regards.
Guofred
