Since any other documents mentioned that can refer to this document, but I don't know how to download it. Please tell me, is NDA required?
I tried the ways as blow...
Solved! Go to Solution.
Once you download the Linux BSP 33.0 from Automotive Software Package Manager, should be a "S32G2_LinuxBSP_33.0_User_Manual.pdf" or inside Software Licensing and support, once you select the "Automotive SW - S32G - Linux BSP (Cortex A53)" and continue to select the BSP version (you will be asked to accept terms and conditions) you will be redirected to the available downloads, one should be the user manual in pdf format.
You could select the "Automotive SW for S32G2 – Linux BSP" within the "Downloads" section in the link below to see if you get redirected to this documentation. You will need to sign-in prior to selecting the option, for the page to correctly redirect you to this documentation.
BSP for S32 MCUs and Processors | NXP Semiconductors
As for the NDA, we do recommend starting your NDA process with NXP. Below will be the FAQs page for NDA within NXP, if you would like to start the process.
Non-Disclosure Agreement FAQs | NXP Semiconductors
Please, let us know.
Thanks lot!
