UART_1
UART_1
969件の閲覧回数
vimalrajendran
Hi ,
      i am using s32G2 board i using uart1 pin PA_13 for TX and PB_10 for RX. but i cant read GPS data. can you give me some suggestion.
This two pin possible for UART or NOT?
Vimal
3 返答(返信)
942件の閲覧回数
vimalrajendran
Hi Bulat,
              in s32g2gen2.dtsi file or linflexuart.c driver file are you telling?
956件の閲覧回数
Bulat
Yes, PA_13 can be used UART1 TX and PB_10 as UART1 RX. Please check if pins are correctly configured and LINFlexD_1 is set to UART mode in your case.
Use a scope to check pins for UART activity.
Bulat
521件の閲覧回数
niranjpo
Hi Bulat,
How UART activity will be generated from u-boot to probe pins on scope.
There is no uart related function in u-boot.
Niranjan
