How to access SEMA42 address on S32G3 ?
xiuli_sun
I am enabling LLCE on S32G3 with vxWorks. When I enable Rx intertupt,  I need to write the sema42.
But when I write it, it will lead to my board reboot and I am sure the address is right.
Then I check in the reference manual, it says that the "You can access these registers only in Supervisor mode. User accesses terminate with an error." chapter 17, Page 766.
So how should I make the driver to work in Supervisor mode?
Looking forward to your replay.
Thanks a lot!
xiuli_sun
We have solved the problem. Thanks a lot !
nxf92355
Hi xiuli sun
Okay, that's good. I conformed that Linux BSP does not contain any driver or information where SEMA42 IP is used.
Regards ,
Tushar
nxf92355
Hi Xiuli Sun
Hope you are doing well
I think supervisor mode is arm related. let me ask to our internal team if any information regarding this. I will update here
Best Regards ,
Tushar
