I am getting confused with the versioning within the "S32G3_ES_SW_ANALYSIS.xlsx" document. It is released on 26.11.2024 with version 3.0:
When I check the document it doesn't have the version 3.0 documented in the revision history:
as well as the date.
For me it seems that this sheet has not been updated.
Please be aware of that for future updates.
Solved! Go to Solution.
Hello, @Jasmin_IM
Thank you very much for the findings, I will check it with the corresponding part.
Chenyin
Hello, @Jasmin_IM
Chenyin
