When I was reading the manual 2.4_Studio_documentation_developers_guide and planning to build a configuration project according to Os_TS_T40D2M10I0R0, I chose the Os module. I found that the Os module only has OsCounter.
How can I get the task, event and other configurations in the manual, and where can I download the Os (4.1.0 AS4.0.2) in the manual?
Thanks for the support!
Hi decoski,
In the MCAL package and RTD package, the Os module is a stub.
To use Os, you can download the OS packages at this link:
https://are.nxp.com/FlexNetCatalog.aspx
Or you can contact EB Elektrobit to get support for this issue.
Dan
Thank you for your reply, but I seem to be unable to open this link. Can you send a copy to me, thank you!
Dear decoski,
I think you can open this link if you had an account on the nxp.com website. Could you capture your screen when you open the link?
Dan
Hi decoski,
If you can not access the website.
I think you should try another way: contact EB Elecktrobit to ask about your OS error.
Dan
Hi decoski,
I discussed your issue with my colleagues. Sorry because I provided you the website is accessible by NXP employees only.
The last version of the Autosar OS 4.0 is available through search https://www.nxp.com/search?keyword=+AUTOSAR+4.0+OS+%28QM%29+for+S32K14x&start=0
The direct download link is then AUTOSAR 4.0 OS (QM) for S32K14x
Dan
