Where can I find xdm containing os event, task?
decoski
When I was reading the manual 2.4_Studio_documentation_developers_guide and planning to build a configuration project according to Os_TS_T40D2M10I0R0, I chose the Os module. I found that the Os module only has OsCounter.
How can I get the task, event and other configurations in the manual, and where can I download the Os (4.1.0 AS4.0.2) in the manual?
Thanks for the support!
nxf78987
Hi decoski,
In the MCAL package and RTD package, the Os module is a stub.
To use Os, you can download the OS packages at this link:
https://are.nxp.com/FlexNetCatalog.aspx
Or you can contact EB Elektrobit to get support for this issue.
Dan
decoski
Thank you for your reply, but I seem to be unable to open this link. Can you send a copy to me, thank you!
nxf78987
Dear decoski,
I think you can open this link if you had an account on the nxp.com website. Could you capture your screen when you open the link?
Dan
decoski
Shows as follows:
Hmm... Can't access this page to check are.nxp.com for spelling errors.
If the spelling is correct, try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN
nxf78987
Hi decoski,
If you can not access the website.
I think you should try another way: contact EB Elecktrobit to ask about your OS error.
Dan
decoski
My other colleagues including overseas friends can't open this link. Why can't you provide a valid link or send me a copy? I don't have an account on eb that can be supported. Can you provide me with an effective help, thank you
nxf78987
Hi decoski,
I discussed your issue with my colleagues. Sorry because I provided you the website is accessible by NXP employees only.
The last version of the Autosar OS 4.0 is available through search https://www.nxp.com/search?keyword=+AUTOSAR+4.0+OS+%28QM%29+for+S32K14x&start=0
The direct download link is then  AUTOSAR 4.0 OS (QM) for S32K14x
Dan
