Updating to S32SDK_S32K1XX_RTM_4.0.1 from S32SDK_S32K1XX_RTM_4.0.0
4,902 次查看
SorinT
I'm currently working with Design Studio for S32 Platform, version 3.3 with S32SDK_S32K1XX_RTM_4.0.0 installed. I am trying to update to update to S32SDK_S32K1XX_RTM_4.0.1 but the new version does no show up in design studio in the installed products list.
What is the proper way to install it, so that it is visible in Design Studio and I can use the example projects & drivers that it provides?
4,872 次查看
Omar_Anguiano
Hello
I'm experiencing issues installing the SDK RTM 4.0.1 since installing it from the executable is not working properly. I'm reporting this issue with the adequate team.
 I will keep you updated about this.
If you have more questions do not hesitate to ask me.
Omar
4 回复数
4,648 次查看
DavidMunoz
What is the solution to this problem? I need to do the same thing and I am having the same problem the SDK is not updated to 4.0.1 version in the project.
4,635 次查看
Omar_Anguiano
The v4.0.1 of the SDK was added in the S32DS: https://www.nxp.com/design/software/development-software/s32-design-studio-ide/s32-design-studio-for...
To install it, go to the tab help->S32DS Extensions and Updates
Omar
4,873 次查看
Omar_Anguiano
Hello
Omar
3,891 次查看
DavidMunoz
Do you have any updates related to this problem?
