I have created a bootable SD Card for the S32R45 EVB by writing the fsl-image-auto-s32r45evb.sdcard image file(use Win32DiskImager).
Insert the SD card into the S32R45 EVB SD slot, and power-on the EVB. It seems unnormal, points out “unable to mount root fs on unknown-block”.
How can I do to solve it?
已解决! 转到解答。
It seems the second partition EXT3 where the rootfs resides, was not written correctly.
Could you insert the SD card in a Linux host and make sure you get 2 partitions in the SD card?
The first one must be a FAT32 and the second one Ext3/Ext4.
Saludos,
Alejandro
Saludos,
Alejandro
