Trouble updating to S32K1_ISELED_RTM_4.0.0
1,897件の閲覧回数
johnathan_weise
I am having difficulty updating to S32K1_ISELED_RTM_4.0.0 from 3.0.0
When I launch the .exe to install, I am directing it to the NXP\S32DS_ARM_v2018.R1\S32DS folder, where all the other installations reside, but I don't see a new folder generated when the install finishes I also do not see any new examples when I launch the IDE and try to make a new program. I do see that the ReleaseNotes_ISELED.pdf file is updated to RTM_4.0.0 however.
Am I directing this to an incorrect folder, or am I missing a step?
1,737件の閲覧回数
dragosrachitan
As the ISELED driver needs to be installed over any SDK RTM 3.0.x so the installation path must be. be NXP\S32DS_ARM_v2018.R1\S32DS\S32_SDK_RTM_3.0.0
The SDK version will still appear as SDK RTM 3.0.0. Please check if the library libiseled_S32K148.a is present in platform\drivers\src\iseled\gcc. If this is the case, the installation was successful, as that library was added in ISELED RTM 4.0.0
Hope this helps,
Dragos
3 返答(返信)
1,737件の閲覧回数
dianabatrlova
Hello Johnathan,
I recommend you to follow the installation guide. Please, see the installation path in step 18. in chapter 4. Installation of S32K SDK ISELED driver
https://www.nxp.com/docs/en/user-guide/S32K-SDK-ISELED-UG.pdf
The available examples are described in chapter 5. Examples in the ReleaseNotes_ISELED.pdf file
Which example you do not see?
Diana
1,737件の閲覧回数
johnathan_weise
I tried installing in the location shown in the image of step 18. It did not seem to work, though the installation said it completed.
When I go to start a new project from example, I do not see a RTM4.0.0 like I d with RTM3.0.0, or the previous beta versions of ISELED.
1,739件の閲覧回数
dragosrachitan
Hope this helps,
Dragos
