SJA1110 L2 Lookup Table Trap Flag
Stefan5
I'm using the S32 Design Studio and config two L2 Lookup Tables for Switch 1 and Switch 2. The first one is working and my traffic forwarded to Port 0, which is the Buffer, but I can't transfer data from the other direction. "Host unreachable"
I use the two RJ45 Ports to connect with each other.
First L2 Lookup Table
Second L2 Lookup Table
Am I right that on the second L2 Lookup Table Port 2 is the RJ45 connector and Port 0 is the ENET Buffer, because the config using cascading?
Thank you and greetings
Stefan
