S32K144 LPSPI clock how to set 40MHZ
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
SPI functional clock (source clock) can be set max 80MHz in Run mode , Function Clock select SPLLDIV2_CLK for 80MHz.
and ProcessorExpert.pe Components lpspicom1: lpspi Baudrate (Hz) is set 40000000, Clock Source is 80000000 is read only.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
NXP FS32K144HAT0MLHT LQFP-64(VDD 3.3V) Read 3V SPI NOR FLASH One Page Data test ! Serial CLK is 24MHz!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Baudrate = SPI functional clock / 2^TCR[PRESCALE] / (CCR[SCKDIV] +2)
Since the SPI functional clock (source clock) can be set max 48MHz in Run mode and
The SCK period is equal to (SCKDIV+2) cycles of the LPSPI functional clock divided by the Prescaler Value TCR[PRESCALE] configuration, so, theoretically, we cannot set a baudrate more than 24 MHz.
However, you can see that the baudrate can be set max to 10MHz in Run Mode in "Table 46. LPSPI electrical specifications" in the DS rev 13.
Using the Master Loopback feature you can set max 20 MHz in Run Mode when MCU runs at 5V power supply.
I would like to suggest looking at the example code located in the S32DS -> File -> New -> S32DS Project from Example
I hope it helps.
Diana
