Hello All,
I'm working in S32K144 MCU for the FlexCAN Communication. I have used the Example Source NON-SDK for FlexCAN, EVB Board flashed the example and tap the CAN_TX Line(PTE5) to the scope and Running the programming can see the CAN Frame Data.
My problems are,
I'm using PTC3 -CAN_TX(ALT3) and PTC2-CAN_RX(ALT3) followed the same Example code only different is PORTC changed.
Please anyone faces the same problem with using PORT C for FlexCAN0
Port C Configuration,
Case 1:
PCC->PCCn[PCC_PORTC_INDEX ]|=PCC_PCCn_CGC_MASK; /* Enable clock for PORTC */
PORTC->PCR[3]|=PORT_PCR_MUX(3); /* Port C3: MUX = ALT3,(CAN0)C_CAN TX */
PORTC->PCR[2]|=PORT_PCR_MUX(3); /* Port C2: MUX = ALT3,(CAN0)C_CAN RX */
Case 2:
PORTC->PCR[3] &= ~(PORT_PCR_MUX_MASK);
PORTC->PCR[2] &= ~(PORT_PCR_MUX_MASK);
Both Case 1 and Case2 i'm not see any Data signls with the scope.
Please let me know if any other configuration required.
Sakthivel K#
