S32K SDK can_pal lack
搜索替代
753 次查看
adria
I am usign processor expert and have added can_pal component to my project. I see there are some features from FlexCAN which can_pal doesn't cover. If I want to use them, what do you recommend me to do:
1. Keep using can_pal and, in case I want to use some of the FlexCAN functions which are not covered by can_pal, directly call those FlexCAN function.
2. Remove can_pal component from my project and start using only FlexCAN.
Adria
标记 (1)
536 次查看
victorjimenez
Hello Adria,
If your application allows you to use FlexCAN instead of can_pal, my recommendation would be to stick to your second option, remove can_pal component from your project and start using only FlexCAN.
TIC
537 次查看
victorjimenez
Hello Adria,
TIC
