undefined reference to `g_pin_mux_InitConfigArr'
428件の閲覧回数
feng_ang
I made an error when compiling this file. I still made an error after updating the patch of version 14
402件の閲覧回数
lukaszadrapa
Hi @feng_ang
did you generate the code before compilation?
Or select in main menu Project -> Generate Processor Expert Code.
This is usually the source of similar errors.
Lukas
2 返答(返信)
403件の閲覧回数
lukaszadrapa
Hi @feng_ang
Lukas
395件の閲覧回数
feng_ang
Thank you. I have solved this problem.
