Hi all. I am using s32ds for projects development. For safety reasons, the unused/remaining ROM must be filled. From other threats I've learned that the remaininngs will be flashed with 0xFF by default. Questions are: 1, will all the unused cells be filled? 2, whats the conquence of 0xFF, I mean, what wouldhappen if the pointer accidently jump to it?
much thanks in advance!
Jiabin.
By default erased flash cells have the value of 0xff.
For safety reasons I do fill memory with a predefined pattern to catch error cases easier.
See FILLing unused Memory with the GNU Linker | MCU on Eclipse how to do this with the linker.
I hope this helps,
Erich
empty ROM has 0xFF value. Prior programming is performed mass erase - all Flash is set to 0xFF.
If program jumps into unused memory - program ends in exception because of unknown instruction.
You may find helpful this thread - https://community.nxp.com/message/1234820?commentID=1234820#comment-1234820
Jiri
