When I try to use the opencv's highgui to show a frame, there is some error, can not find gtk support
932件の閲覧回数
justforfunl
The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Carbon support. If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script.
Question 1: is the S32 Design Vision Studio's ocv library compiled with GTK2.0?
Question 2: How to compile the GTK for s32v234 kernel.
Question 3: How to compile OpenCV With GTK2.0 for Arm or with QT.
ラベル(2)
タグ(4)
0 返答(返信)
