What happens if I set tval0 in lpit0 to 0? (S32K144 LPIT0)
909 次查看
ym1
hello everyone!
I use the compare mode of lpit0  and accidentally set tval0 to 0 in the program. I find that cval0 starts count from 0xFFFF_FFFF. Why?
Thanks.
标记 (3)
798 次查看
Robin_Shen
Hi 永锋 季,
00000000000000000000000000000000b - Invalid load value in compare mode
00000000000000000000000000000001b - Invalid load value in compare mode
Robin
4 回复数
798 次查看
Robin_Shen
Hi 永锋 季,
The Access of Current Timer Value CVAL is RO(read only). I don't know why you write 0 to it.
I am not sure if it was caused by below:
Robin
798 次查看
ym1
Hi Robin_Shen,
Sorry, I want to say tval0. So my question is:
799 次查看
Robin_Shen
Hi 永锋 季,
Robin
798 次查看
ym1
Thank you,Robin_Shen. I got it.
2020-05-21
