Hi @Senlent
Thank you for your continuous support.
I'm using the API Emios_Pwm_Ip_SetPeriod for setting the period for instance 0 and 1 with the following configurations.
In autogenerated code it mentioned as Set period is only working in OPWFMB mode. For instance 0 OPWFMB mode is supporting, and it is working as per we expected.
But for instance 1, OPWFMB mode is not supporting, and we tried with the following configurations for instance 1.
Using with this configuration, all EMIOS 1 instance channels are not working as expected.
Could you please give the guidance to resolve this.
Awaiting for your response.
Thank you
