S32DS
S32DS
1,520件の閲覧回数
QJ_HAPPY
Dear NXP Hello,
I am using the S32DS.3.4.
I have a problem when i compile an example,
I couldn't debug the project and the console outputs this message:
d:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v6.3/gcc-6.3-arm32-eabi/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/real-ld.exe: cannot find crti.o: No such file or directory
d:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v6.3/gcc-6.3-arm32-eabi/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/real-ld.exe: cannot find crtbegin.o: No such file or directory
d:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v6.3/gcc-6.3-arm32-eabi/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/real-ld.exe: cannot find crt0.o: No such file or directory
what should i do
Thank you in advance for your help,
Mr QJ
3 返答(返信)
1,490件の閲覧回数
jiri_kral
what example you are trying to build and what is your target MCU?
Jiri
859件の閲覧回数
AbhishekK
Hello Jiri_Kral,
I am facing above linker issue .please provide me a solution for it .I am using S32K144 MCU .and I am using GNU compiler for it .
Thanks in advance
1,386件の閲覧回数
QJ_HAPPY
the problem has been solved,I updated GCC related packages thank you
