S32DS for ARM 2.2 path setting
855 次查看
fanziyu
What's the difference between these two lines?
I have used the second method in the past and have found no problems.Is there any risk?
Thanks!
845 次查看
jiri_kral
technically there is no difference. Both methods builds absolute path to your files from S32DS variables.
768 次查看
NamLee
Hi fanziyu,
I think it's the same, but i prefer the 2nd just because it used ok in the past xD
Thank you,
Nam
846 次查看
jiri_kral
