S32DS command-line interface mode
3,254 次查看
kayas_ahmed
Hello folks,
Does S32DS support the command-line interface in Linux?
Kayas Ahmed
标记 (3)
7 回复数
307 次查看
maohuynh2207
How to use with s32k3xx mcu. S32D Studio 3.4
3,116 次查看
jfrey
S32DS itself does not. You can supposedly use the Makefiles that S32 generates but I have found them to be unreliable and a mess to debug/read.
I have containerized the S32DS PA build process so that you can repeatably build software in the same way every time:
There is an example project here: GitHub - AutomotiveDevOps/LINFlexD_UART_MPC5744P_Docker: Single Repo Example for LINFlexD_UART_MPC57...
3,116 次查看
kayas_ahmed
Thanks Jed, I did try with make files generated by S32 and found it bit messy, so went with cmake build at last. Anyways Thanks.
2,712 次查看
kasundinesh
Do you have any examples or a template project on how to migrate to CMake?
3,116 次查看
jfrey
Do you have a public Git repository for the CMake build? I would be interested in migrating from Make to CMake.
3,116 次查看
jiri_kral
command line interface for what purpose? For install or for project build?
Jiri
3,116 次查看
kayas_ahmed
For building project in CI
