S32 pemicro port connection error
cristianchacha
I try to use S32 Desing studio in linux, process compilation is ok, but when I want debug with PEmicro , I have a problem with port connection.
From time to time, the connection is succesfully because port number connection change in each connection, but I need to try over and over again, so if there any parameter to configure port number.
I mean "44542" and "60484" , could be statically values ? In my windows machine I saw that correct values are 55778 and 55780 , and every time use these.
Thanks a lot.
Tags (2)
juan_see
Hi @cristianchacha ,
Could you please visit the pemicro website and submit a support request there? That way, the issue can be investigated by the PEmicro team directly.
Juan See
PEmicro
