Regarding s32k116 make file
718 次查看
venkateswarabal
I am using S32DS for ARM (Ver:2018.R1 )on S32K116 projects and would like to use IAREW(Ver:IAREW 8.0) to do the compile using gmake. Can i get any sample make file for S32K116 controller?
553 次查看
mikedoidge
Please review the doc HOWTO: Install IAR Eclipse plug-in into S32 Design Studio for ARM. This provides details on how to incorporate support for IAR within S32DS. After the plug-in is installed, you can use the New Project Wizard to create an application project for IAR toolchain and the makefile will be generated for you.
Hope it helps!
Mike
