Problem with S32k144 48 PINS - SDK
次の代わりに検索
610件の閲覧回数
senthilnathan_v
I have migrated from 64 pin to 48 pins. First problem is it was always going to trap because the clock initialization for the peripherals from SDK had no effect. Then i need to do it manually in the main function.
//***** Added Manually ***
// LPTMR0
if(PCC->PCCn[PCC_LPTMR0_INDEX] & 0x40000000){PCC->PCCn[PCC_LPTMR0_INDEX] = 0x80000000;}
PCC->PCCn[PCC_LPTMR0_INDEX] = 0xC2000000; // enable clock, use SIRCDIV2 clock, no clock division
/* Initialize LPTMR */
LPTMR_DRV_Init(INST_LPTMR1, &lpTmr1_config0, false);
INT_SYS_InstallHandler(LPTMR0_IRQn, lptmrISR, (isr_t *)NULL);
INT_SYS_EnableIRQ(LPTMR0_IRQn);
The timer interrupt and pin toggling was working later.
Now i have problem with the LIN and LPUART. The LPUART interrupt is not hitting even after the clock initialization for LPUART1.
/* Configure Clock for LPUART1 */
PCC->PCCn[PCC_LPUART1_INDEX] &= ~PCC_PCCn_CGC_MASK; /* CGC=0: Clock disabled to modify PCS */
PCC->PCCn[PCC_LPUART1_INDEX] &= ~PCC_PCCn_PCS_MASK; /* Clear PCS field temporarily */
PCC->PCCn[PCC_LPUART1_INDEX] = 0xC3000000;
I have tried both LIN slave and LIN slave baremetal from SDK.
Is the SDK for 48 pin package is complete?
or Still any update can be expected?
タグ(6)
587件の閲覧回数
senthilnathan_v
Thank you for the reply. I think i made some mistake in clock configuration. Now the LIN is working fine as expected.
I got support from field application engineer, NXP. He guided me to resolve the problem
596件の閲覧回数
Robin_Shen
Hi senthilnathan_v,
Would you please let me know the version of your S32K SDK?
Processor Expert already supports 48 pin package in SDK RTM 3.0.0. (It should have been fixed in a later version too.)
Here you can see I change the CPU to 48 pins for lptmr_periodic_interrupt_s32k144 example.
It was able to work without clock issue.
Robin
588件の閲覧回数
senthilnathan_v
