Hello Team,
I started using S32 Design studio from few days.
currently I am working on S32K142 microcontroller for sound application.
When I try to configure any peripheral from Peripheral Option , It is showing that Peripheral not present in toolchain project. If I select All available component then it is giving below warning.
Below are some details of project.
Please help me with explaining what to do in steps.
Thanks!
Hi MohitManvar,
According to the "6.3 Compiler and IDE versions" of S32SDK_for_S32K1xx_RTM_4.0.1_ReleaseNotes.pdf:
GreenHills compiler v. 2017.1.4
IAR compiler v. 8.11.2
GCC compiler for ARM v. 6.3.1 20170509
Wind River Diab Compiler v5.9.6.2
ARM Compiler 6.6.1 Long Term Maintenance
S32 Design Studio 3.3 IDE
Do not use S32DS v3.5, please use S32DS v3.4+S32K1 SDK RTM4.0.3.
Sorry for the inconvenience we bring you!
Robin
I tried with installing S32DS 3.4 version as mentioned in your answer but Still I'm facing same issue.
Please select NXP GCC 6.3 for Arm 32-bit Bare-Metal Toolchain when create S32DS Application Project.
After you double-click the component you want to add, this warning will disappear.
Hello Robin,
I tried same as your given steps but still having same warning.
please provide solution ASAP.
Thanks!
Have you tried S32DS v3.4+S32K1 SDK RTM4.0.3? It looks like your project is still using the old S32K1 SDK RTM4.0.1
Robin
