Peripheral configuration issue
Search instead for
MohitManvar
Hello Team,
I started using S32 Design studio from few days.
currently I am working on S32K142 microcontroller for sound application.
When I try to configure any peripheral from Peripheral Option , It is showing that Peripheral not present in toolchain project. If I select All available component then it is giving below warning.
Below are some details of project.
Please help me with explaining what to do in steps.
Thanks!
Robin_Shen
Hi MohitManvar,
According to the "6.3 Compiler and IDE versions" of S32SDK_for_S32K1xx_RTM_4.0.1_ReleaseNotes.pdf:
 GreenHills compiler v. 2017.1.4
 IAR compiler v. 8.11.2
GCC compiler for ARM v. 6.3.1 20170509
 Wind River Diab Compiler v5.9.6.2
 ARM Compiler 6.6.1 Long Term Maintenance
S32 Design Studio 3.3 IDE
Do not use S32DS v3.5, please use S32DS v3.4+S32K1 SDK RTM4.0.3.
Sorry for the inconvenience we bring you!
Robin
MohitManvar
I tried with installing S32DS 3.4 version as mentioned in your answer but Still I'm facing same issue.
Robin_Shen
Please select NXP GCC 6.3 for Arm 32-bit Bare-Metal Toolchain when create S32DS Application Project.
After you double-click the component you want to add, this warning will disappear.
MohitManvar
Hello Robin,
I tried same as your given steps but still having same warning.
please provide solution ASAP.
Thanks!
Robin_Shen
Have you tried S32DS v3.4+S32K1 SDK RTM4.0.3? It looks like your project is still using the old S32K1 SDK RTM4.0.1
Robin
