NXP S32DS 2018.r1 activation error
Agham
Mehul_Patel_NXP
Hi, @Agham ,
I have extended your license through end of December - 2026.
Please refresh the activation.
Thank you. Best regards.
- Mehul Patel
Agham
Activation code : B56F-371D-15D2-5A4E
Mehul_Patel_NXP
Hi, @Agham ,
- Mehul Patel
Agham
Hi Mehul Patel,
we are facing the issue with activation
Activation Code:-B56F-371D-15D2-5A4E valid till Dec 2026
Total Number of Licenses: 100
Mehul_Patel_NXP
Hi, @Agham ,
As I see activation attempt is successful. Please let us know if you any further issue.
Thank you. Kind regards,
- Mehul Patel
Agham
Hi Mehul Patel,
Mehul_Patel_NXP
Hi, @Agham ,
Please can you check that you are using proper activation code for the S32DS for ARM v 2018.
If you are using different Design studio version but not for the S32DS for ARM v 2018, you also need have valid separate license activation
Please can you tell the activation code.
Thank you, best regards,
- Mehul Patel
