MPC5744P s32dc and AMMCLIB
次の代わりに検索
1,489件の閲覧回数
dyc09052110
HI:
I'm programming MPC5744P by S32DS.There is a problem about MPC574xP_AMMCLIB_V1.1.7. When i build my project,It reminds me "C:/Freescale/AMMCLIB/MPC574xP_AMMCLIB_v1.1.7/include/SWLIBS_Defines.h lsp.h:No such file or directory".I also can not find the lsp.h in my computer.
Great thanks!
YongChao Ding
4 返答(返信)
968件の閲覧回数
stanish
Indeed lsp.h is missing in S32DS for Power v1.1 this is a known issue.
This will be fixed in coming release S32DS for Power v1.2 that should be released by the end of March 2017.
You can use attached file in the meantime.
please copy the file into both EWL include folder:
<S32_Power_v1.1>\S32DS\e200_ewl2\EWL_C\include\pa\lsp.h
and NewLib include folder:
<S32_Power_v1.1>\Cross_Tools\powerpc-eabivle-4_9\lib\gcc\powerpc-eabivle\4.9.2\include\lsp.h
Hope it helps.
Stan
968件の閲覧回数
embedded_eng
Try to setup PATH variables in a correct way.
968件の閲覧回数
dyc09052110
Hi:
I have already installed the MPC574xP_AMMCLIB_v1.1.7 according to its documentation.I also have set up the path as described in the documentation correctly,but it still prompts this error.In my opinion,even if my path is set incorrectly, but after I installed S32DS and MPC574xP_AMMCLIB_v1.1.7, lsp.h header file should be in my computer inside. But I did not find this file in my computer.How should I solve this problem?
Great thanks!
YongChao Ding
968件の閲覧回数
embedded_eng
I'm not familliar with AMMCLIB. But, I know that you can't compile your code if you included a PATH for a variable (file) which doesn't exist.
Try to understand if lsp.h is really needed, if not, exclude it from build, if yes, you should find it somewhere else. Also, make sure that AMMCLIB is not unpacked your lsp.h somewhere else, or MAYBE lsp.h can be found in older versions of AMMCLIB (maybe you should first install older version, that update).
Regards.
