Initialization sequence error
832件の閲覧回数
mike_unger
Working with a EvalKit  for SAF85xx. I recently upgraded my S32 DS from 3.4 to v3.5. Can not download via the debugger successfully. Get this error - "ccs:Initialization sequence error in command 0xF". I have had the debugger working fine in the past. Any info on what it means? A clue where to look? Thanks.
タグ(2)
816件の閲覧回数
VaneB
Hi @mike_unger
I'm really sorry for the inconvenience this might cause you, but as the information of the SAF85XX is under NDA (Non Disclosure Agreement) the information of it it's not public, and I'm not able to check and verify as I do not have the information due to the security levels when working with an automotive part such as this.
If you are already working with SAF85XX, I believe you should already have a contact that helped you getting the information, could you please contact that person for further support on this part?
B.R.
VaneB
2 返答(返信)
781件の閲覧回数
mike_unger
Right, that makes sense VaneB, I should have realized that. Yes, I reached out to our contact and got some help. Thanks.
817件の閲覧回数
VaneB
Hi @mike_unger
B.R.
VaneB
