I was using version 3.4 of the S32 Design studio IDE. But I changed my computer and installed version 3.5. When I open every project folder I import, the IDE directly gives an error. There is no problem in compiling, but I get the following error;
"Current version of the toolchain is no longer supported. It is necessary to perform project migration to a later version."
As a result of this process, should I reinstall the old version IDE from scratch? Or is there another solution?
Your issue seems to be the compatibility of the IDE version and the packages installed.
Reinstalling the old version could be a solution, however if you can share with me the packages you use I can verify if there are available for the 3.5 version of S32 Design Studio.
Please let me know.
